Cleaning sealed type air cleaners - NCRS Discussion Boards
  • Bob S.
    • August 12, 2007
    • 185
    What is the proper/best way to clean the sealed type air cleaner on my '59/230?
    Sully
  • Bill I.
    • January 28, 2008
    • 554
    Re: Cleaning sealed type air cleaners
    Hey Irish, noticed you have not got any hits on your ?. But tell me, what is a sealed type air cleaner? Thanks, Bill Irwin (also Irish).
    • Roy B.
      • January 31, 1975
      • 7044
      Put it in solvent for some time , shake it then air blow it clean
      • Stuart F.
        • August 31, 1996
        • 4676
        I believe they are like what was common back in the day, i.e. some form of captive media such as hogs hair more commonly used in smaller filters such as the oil filler/breather caps or single/dual throat carb filters of the day. The "Stelling Hellings" chrome bonnets come to mind. All of us with three duces on our early Chevy V8's had them as they looked so cool. Many 4-barrel air cleaners also used the same type stuff, both OEM and after market. They sometimes were sealed, while others were 3 piece (top, bottom, and an element made up of an inner and outer Stainless perforated ring with the hog hair media inthe middle).
        Stu Fox
        • Bill I.
          • January 28, 2008
          • 554
          Thanks Stu, NOW I remember. Also remember oil breather caps on the valve covers also like that. Bill.
          Last edited by Bill I.; November 11, 2008, 07:30 PM. Reason: remember what they were called
          • Bob S.
            • August 12, 2007
            • 185
            Thanks Roy. I thought is would be that simple but wanted to be sure.
            Sully
            • Steven B.
              • June 30, 1982
              • 3976
              As Roy stated, put in solvent and air dry. I always soak mine up to the side and try not to immerse the top flame arresting material, then use compressed air then air dry. A little polishing and then back on the car. I believe one of the old manuals says to soak in gasoline. I don't do that anymore and I don't lean over the carbs while adjusting anymore either.
              • Roy B.
                • January 31, 1975
                • 7044
                You take the fun out of it
                • Steven B.
                  • June 30, 1982
                  • 3976
                  I leaned over toooooooo far---just once. It takes awhile to regrow eyebrows! My new "sun burn" hurt for a week! As for the gasoline--- you hear a pop from the back fire and see white smoke come out of the air cleaner louvers
                  • Stuart F.
                    • August 31, 1996
                    • 4676
                    Steve;
                    You have to be ready put your hand over the carb. Remember when we used to choke to start that way?
                    Stu Fox
                    • Steven B.
                      • June 30, 1982
                      • 3976
                      Steve;
                      Stu Fox
                      Yeah! The good old days! I used to choke like that! I used to take a Saturday, when not working, and adjust valves, set carbs and timing, clean or replace plugs and points, change oil and filter, lube and go to bed---Then Sunday, wash, polish and wax. That makes me tired just thinking about it now.
