Buying the right Antifreeze for my C1? - NCRS Discussion Boards
  • Jeff M.
    • May 31, 2006
    • 30
    I own a 1961 car and just purchased a new Dewitt aluminum radiator system. I called DeWitts to get their recommendation on which antifreeze product to use and they recommend using XEREX G05. But this product is recommended for Dodge/Chrysler products. They were clear that either using distilled water or a pre-mixed antifreeze version was even more important then which fluid to use. Has anyone used this product or do you recommend a different product? Thanks,
    Jeff
    45885
  • Jim D.
    • 2884
    Re: Buying the right Antifreeze for my C1?
    Zerex G-05 and distilled water is what you want to use. I use it in two of my cars.
    Jim
    • Larry M.
      • January 1, 1992
      • 2691
      Jeff:
      It's ZEREX G-05, and is probably the best out there for our older cars. Used and specified by Mercedes, Ford, and Chrysler. It is a HOAT type....Hybrid Organic Acid Technology.
      I have used G-05 in my 1967 car for the past 5-6 years with no issues. If you go to the Zerex website and read their technical info, you will find that G-05 protects all metals without corroding/affecting the solder used in our older cars cooling systems.
      Having said this, the Prestone golden or yellow/green color antifreeze should also work well. Just stay away from DEX-COOL or DEX-COOL compatible types. And as Tom says, used a good quality distilled water to flush and mix. It's cheap insurance.
      Larry
      • Jeff M.
        • May 31, 2006
        • 30
        Jim and Larry,
        Thanks for responding and sharing your recommendation, next time I will spell the product correctly.
        Jeff
