Turbo 400 Pan Bolts - NCRS Discussion Boards
Turbo 400 Pan Bolts
  • Martin N.
    • July 30, 2007
    • 594
    Turbo 400 Pan Bolts
    I'm looking to do a trans filter change on my 1974 Turbo-400 trans in the next couple of weeks and wanted to replace the mix of bolts and washers that "Bubba" used at one time and use as close to OEM spec's as I can. Anyone ever order from AMK Restoration Bolts? I found what appears to be what I need (other than the longer bolts to hold the shift cable bracket) for the pan other than no head markings. Were there head markings on these bolts in the first place? THANKS.
    Marty
