another 4360 ( Mike ) - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
    Mike is this what you had in mind?
    Joe
  • Mike M.
    • May 31, 1974
    • 8409
    Re: another 4360 ( Mike )
    that's the correct 45 degree elbow.notice the width of the plateau as this is where the repo differs from an original.mike
    • Roy B.
      • February 1, 1975
      • 7044
      Made by Imperial and not seen on many restored Corvettes Even the 55 had it~
      • Joseph T.
        • April 30, 1976
        • 2074
        Re: another 4346 ( correction )
        I meant to say another 4346...
        Roy is there a place to buy these original fittings?
        Joe
        • Mike M.
          • May 31, 1974
          • 8409
          i know of no souirce for the original fitting. tom and jay maxwell supply the repo/replacement and they add in the driveline.mike
          • Stuart F.
            • August 31, 1996
            • 4676
            Hey guys, pardon my ignorance. But, exactly what part are you referring to? Just the 45 degree elbow or the flexible gas line to it? I had a flex line like that until a while ago when I took it out to look at it and it crumbled in my hand (bit old and brittle). Is the elbow unique? It's a little hard to tell from the picture, but it looks like those I've been dealing with on my AFB carbs (filter to carb) which, of course, are pretty standard brass or chromed brass fittings.
            Thanks for your patience.
            Stu Fox
            • Roy B.
              • February 1, 1975
              • 7044
              Joe
              Some one sells them but not original,should be seen on all C1's that I know of no matter what the pump # is! The hose can be found on e-bay . Other wise the original shorter hose can be hard to install to the pump!
              • Richard T.
                • February 1, 1979
                • 858
                I thought that "Weatherhead" made these fittings. Both my 57 and 62 have them and both have the Weatherhead logo stamped on on of the flats. Rich
                • Roy B.
                  • February 1, 1975
                  • 7044
                  It had the same logo as the 54 6 banger fuel line fitting to Carb and I think they were made by Imperial but as always I can be wrong
                  • Richard T.
                    • February 1, 1979
                    • 858
                    Roy,
                    I'm reasonably sure the one in my 62 is an original and it's a Weatherhead. I'll take some pictures when I get a chance. Rich
                    • Richard T.
                      • February 1, 1979
                      • 858
                      Here are two pictures of the original C-1 fuel pump fitting. The first picture shows an original fitting mounted on a 4360 pump. The second shows an original on the left side and a repo on the right side. You can see the "Weatherhead" logo on the original part. This is what I have om both of my cars and I believe it's original. These pictures are from the late Rev. Dale Pearmans collection. Rich
                      • John D.
                        • December 1, 1979
                        • 5507
                        Rich, I agree that weatherhead also made these fittings. NAPA used to sell them.
                        The 57 low HP FI's also used the same configuration as this fitting except it was a tad smaller.
                        What size is the threads for the fuel pump fitting. I am going to guess it's 1/8" pipe that screws into the pump. But what about the fuel line. What thread is that. Same thread? Thanks, JD
                        • Roy B.
                          • February 1, 1975
                          • 7044
                          Well that Clears that up I thought it was Imperial thanks , love how we can post pic's now
                          • Mike M.
                            • May 31, 1974
                            • 8409
                            our 57 250 hp pass car and the 250 PG vette as well as the late 283 hp vette all have their original 45 degree fittings and they don't differ. put yer helmet on john, and get back in the game.mike
                            • Barry H.
                              • April 30, 1976
                              • 213
                              John, 1/4" pipe thread both in & out. Barry
