Alternator adjustment bolt - NCRS Discussion Boards
  • Curt C.
    • May 31, 2000
    • 49
    What is correct bolt configuration for a 1966 alternator? Bolt, lock washer and thick washer or bolt, star washer and thick washer. How about for a 1964? Thanks.
    Re: Alternator adjustment bolt
    Curt -
    '65-6-7 all use the same split lock washer under the bolt head.
      • 43288
      Curt----
      For 1966, it's bolt, external tooth star washer, and thick flat washer. For 1964 it's the same order, but I think a split lock washer was used instead of a star washer.
      • Joe C.
        • August 31, 1999
        • 4598
        Curt -
        The 1965 Judging Manual has it as a star washer. Which is correct?
        • Gary S.
          Super Moderator
          • February 1, 1984
          • 460
          I have lots of pictures of orig alternator adjust bolts/washers...but no 64's. Toothed washer seems most used for 65, 66 and 67. I do have one 65 with a split and another 67 with a split washer. Attached are what appears to be original pictures...one of each year...65, 66, 67. Gary
          Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
          • Joel T.
            • April 30, 2005
            • 765
            I recently had my 1965 judged and lost 1 point because I had the split washer as opposed to the star washer.... My understanding is that 63-64 used the split and 65-67 used the star.....
            • Michael H.
              • January 29, 2008
              • 7477
              For 63, the AIM calls for a 187119, L washer. It's described in other GM doc as a split lock washer, medium.
              For 66 with 327, the AIM calls for a 138485, external tooth lock washer.
              For 66 with 427, The AIM calls for a 187119, split lock washer.
              Small block and big block were different for 66???
              What part numbers are shown in the 64, 65 and 67 AIM's?
                • 15640
                FWIW We expect to see a toothed washer on 1968 and early 1969, with a split lock washer after that.
                • Gary S.
                  Super Moderator
                  • February 1, 1984
                  • 460
                  For what it is worth, here are 3 pictures of very original cars with split washers. Always a chance the lock washer could have been changed, but the thick washer and bolt look original as does the split lock washer. These are from a 65 fuel car Vin 11774, 65 396 car vin 15726 survivor and a 67 427/400 AC coupe vin 20460. The 396 pictures when enlarged looks to be a split washer. So the question is, was the toothed washer really used 100% of the time. Also, in my prior post of 3 pictures, the toothed washer has squared ends unlike the pointed end lock washers the supply houses send you.
                  Gary
                  • Timothy B.
                    • April 30, 1983
                    • 5202
                    My 67 corvette has a external tooth washer at this location and the part # called out in the 1967 AIM is 138485. The 1963 washer in the AIM is as Mike posted.
                    What's interesting is that the washer called out in section 12 page A-7 for the 63 horn mounting is 138485 and we know the horn bolt is 5/16" (same size as alternator) and the horns ground at the core support to work properly so I think it's safe to say star washer here and lock washer at alternator for 63.
                    • Joe C.
                      • August 31, 1999
                      • 4598
                      Originally posted by Michael Hanson (4067)
                      For 63, the AIM calls for a 18711, L washer. It's described in other GM doc as a split lock washer, medium.
                      For 66, the AIM calls for a 138485, L washer. It's described as an external tooth washer.
                      1965 AIM:
                      SBC: 138485 #*
                      #: Note 1 (6/26/64): Was 187119 (?partially unreadable)
                      396: 187119 *
                      * FWIW all lock washers shown in both drawings appear to be split
                      SO,FOR SBC 1964-1965 BUILT AFTER 6/26/64, THERE WAS A CHANGE IN WASHER FROM SPLIT TO STAR. NEED VERIFICATION OF PART NUMBER!!
                      FOR BBC (ALL) WASHER WAS 187119 (SPLIT)
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Originally posted by Joe Ciaravino (32899)
                        1965 AIM:
                        SBC: 138485 #*
                        396: 187119 *
                        If the 65-66 AIM's are accurate, 65 and 66 big blocks used a split lock washer and 65-66 small blocks used an external tooth washer.
                        For what it's worth, my 66 big block has a split lock washer. It doesn't have the orig alternator but I believe the bolt and washers are probably original.
                        Still like to hear what's shown in both SB and BB sections of the 67 AIM.
                          I'd correct my earlier post, but there's no "edit" button available. '65-'6-'7 small-blocks all used the same 138485 external-tooth star washer under the bolt head; same one that's used on the washer nozzles and under the head of the C60 passenger side horn bolt for the ground wire.
                          • Gerard F.
                            • June 30, 2004
                            • 3806
                            Michael,
                            The 67 JG calls out an external tooth star washer for both small block and big block. My late 67 S/B with my original alternator, and I believe original bolt setup, has an external tooth star washer under the head of the bolt and a thick flat washer under.
                            The bolt head marking is a "NAT" within 3 spokes, which varies from the callout in the JG.
                            Wonder if there there are other 67's with the "NAT" head markings
                            Jerry Fuccillo
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              Originally posted by Gerard Fuccillo (42179)
                              Michael,
                              Thanks Jerry. I wonder what the 67 AIM shows for big block?
