C1 Conv Top Frame - NCRS Discussion Boards
C1 Conv Top Frame
  • Jeff C.
    • September 30, 1997
    • 233
    C1 Conv Top Frame
    Are there any differences between the top frames for 1958 through 1962 that would affect the fit and sealing on the car?
    Jeff
  • Greg M.
    • April 1, 1998
    • 119
    Re: C1 Conv Top Frame
    The 1958-1960 conv top frames are all about the same. It seems like I remember the 1958 top frame has a slight difference above the side windows.
    The 1961-1962 frame will only work on those two years unless you change the rear frame that fits on the deck lid. There is a raised portion in the middle that used on a 1958-1960 would leave quite an opening above the deck lid. I am sure someone will chime in with more precise instructions!
    Good Luck
    Greg
    1960 Corvette
    NCRS #30406
