1964 Parking Lights/Turn Signal Lens - NCRS Discussion Boards
  • Chuck D.
    • January 30, 2007
    • 11
    On a 1964 Corvette Roadster, what is the proper orientation of the (2) screws holding the lens on the light housing:
    A. Vertical at 12 and 6 o'clock
    B. Horizontal at 9 and 3 o'clock
    I think mine are incorrect as they are currently (B). If wrong, how do I adjust them to be correct for judging?
    -Chuck
  • David D.
    • January 1, 2005
    • 416
    Re: 1964 Parking Lights/Turn Signal Lens
    Chuck,
    Assuming you are talking rear lights.....Don't know fronts, but if still a question I could go out to garage and look.
    I have a '64 coupe, but I don't think there is a difference....Mine are 'B' orientation, as are yours. At the bottom is the white wicking and no place for a screw.
    David
    • Donald T.
      • September 30, 2002
      • 1319
      Rears are horizontal or 3 and 9 with the hole for the wick at the bottom. Fronts are vertical or 12 and 6.
      • Tom H.
        • December 1, 1993
        • 3440
        Agreed, the fronts should be 12 and 6. A good body man should be able to assist in getting these put back right. You'll have to remove the light housings to see what you have to work with in there. Should be an easy fix. Pretty common to find them in the configuration yours are in.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
