My first show ...Waco - NCRS Discussion Boards
  • David W.
    • February 29, 2008
    • 1
    Wow!!! what an event,never saw so many beautiful vettes. I am new at this,bought a 66 427/390 ac coupe about a year ago.It was sold as built to NCRS specs,in many ways it was but after going over it with my new Tech. Manuel Judging Guide I also found A lot of items were not correct. So I changed,fixed painted as many items as I could and off to Waco we went a journey of 1300 miles.By the time we reached Waco I couldnt tell you what month it was.Enjoyed the show very much thought I might be able to achieve 2nd. flight.However after the show was over I found our team leader and it was only then I found that my trim tag had a problem.A problem I asked? Well seems the tag was not factory original.Now very disappointed. I have two questions. 1. Why was I not told about this when it was first discovered,as it seems the Judging Guide explains. 2. Is there any way to make it correct for this car?
    David Welsh
  • Gary C.
    Administrator
    • October 1, 1982
    • 17940
    Re: My first show ...Waco
    bump - David, moved your thread to the Technical forum from the Help forum. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Bob D.
      NCRS Shipping Data Report Manager
      • April 30, 1996
      • 795
      David
      I'm glad youenjoyed the show at Waco. As to othe why you were not told about the trim tag at the time, I cannot answer that. I believe the team leader should have discussed that with you so that youdid not recieve a big surprise later. Is there a way to make it right? Unless you can find the correct original trim tag, probably not. I know that is not the kind of news you want to hear. If you would like to talk it over with someone, give me a call. You should have my phone number from the Waco paperwork. I'll also send it to you when I send your sheets out.
      • Lyndon S.
        • April 30, 1988
        • 1027
        So did you get disqualified? Did you get some type of flight?
        • Joel F.
          • April 30, 2004
          • 659
          Wow, sorry to hear that David. Does your car have any other documentation that might substantiate the car's configuration in lieu of a trim tag?
