template 1966 hood and side emblems - NCRS Discussion Boards
  • William K.
    • 37
    does anyone have a template for a 1966 hood and side emblems. thanks
  • Ernie F.
    • March 31, 1975
    • 107
    Re: template 1966 hood and side emblems
    The assembly manual on UPC 1 sheet F1 will only tell you the dimensions on the front emblem based on the existing dimples in the upper surround panel. Not fair if you have installed a new surround panel, the dimples are not there. Let me see what I can get for you tomorrow.
    The hoods were already drilled at the factory before they were installed.
    On a good note, the hood will have holes in the back side where the emblem was to be drilled. You can usually center one of the holes for the hood and then drill the others based on this hole. I can try to measure this one for you tomorrow as well.
    Ernie
    • Ernie F.
      • March 31, 1975
      • 107
      I took these this mornig off a car in our shop. I hope this helps and please someone verify this! I am not sure how close this is since I do not know the history of this car.
      Given the measurements I've taken and those from the AIM, you may be able to get it.
      • William K.
        • 37
        thanks for the quick reply. do you also know about the side fender emblems?
