!967 STD steering column - NCRS Discussion Boards
  • Patrick O.
    • January 1, 1991
    • 26
    I'm about to restore my std steering column. My car is a very early number and very original when I dissassembled it. I carefully removed a piece of thin vinyl that had sponge backing from the area where the metal is expanded for the crush zone. I have looked for a replacemnet in all the major suppliers and have not been able to find it. Is it available somewhere I haven't looked? Or are they just using vinyl from a fabric store? Thanks
    Re: !967 STD steering column
    Patrick -
    I'm not aware of any reproduction source for that vinyl sleeve that covers the mesh portion of the column.
    • Patrick O.
      • January 1, 1991
      • 26
      Thanks John. If thats the case . What is everyone doing to replace this?
      • Stephen L.
        • May 31, 1984
        • 3158
        That piece of vinyl covering the crush area of the column is a formed piece that is a partial cone on each end.
        Haven't seen a repop yet
        You might find one in the scrap yard on a vintage GM product. I'm assuming that the columns are similiar in the crush zone area.
        • Jim S.
          • August 31, 2001
          • 730
          The collapsible mesh part of a Corvette column is a smaller diameter than all the other GM first gen energy absorbing columns. One exception; Corvair used the same small diameter mesh jacket as well. So I think that you are going to be looking for a rare part.
          I think that the 1967 and 1968 mesh sections are the same. So the vinyl cover would be the same. I am quite sure that the standard (non-adjustable) column mesh section is the same as the telescoping column.
          Jim
            • 43236
            Paul-----
            I can't find any indication that the fabric covering was ever available from GM as a separate part. I think it was supplied as part of the jacket assembly or the complete steering column but it was not otherwise serviced.
            • Brian T.
              • September 30, 1990
              • 190
              I had an NOS cover, I think I saved the packing. It was in a cardboard tube with a metal cap on each end. Most of the time we are able to reuse the cover. It was installed with a heat source. We use a soldering iron when restoring these. If anyone is interested in the part number, etc. send a PM to me and I will respond on Monday.
