Diff Posi Tags Red Plastic or Metal 4 A '69??? - NCRS Discussion Boards
  • Jamie F.
    • May 20, 2008
    • 337
    I've seen the red triangle tags and and the long metal tags. What's the story on these? What's correct for a late '69???
    Thanks!!!
    • 15616
    Re: Diff Posi Tags Red Plastic or Metal 4 A '69???
    Late 1969 will be the same as my early 1970. Red plastic.
    • Anthony S.
      • April 30, 1998
      • 156
      The 68-69 Judging Guide info only discusses the red plastic warning tag. So I would expect to see all 69 cars having the same plastic tag. - Tony
        • 43248
        Tony----
        Yes, but there are two different red tags. The configuration is the same but one reads " Use Positraction Diff. Lubricant Only" and the others reads "Use Limited-Slip Diff. Lubricant Only". The first of these is the one used for all 1969's.
        • Warren F.
          • December 1, 1987
          • 1516
          Thanks!!!
          I expect that the long metal tag your referring to is the part # for a manual transmission; such as M20, M21 or M22.
          • Jamie F.
            • May 20, 2008
            • 337
            No, actually I was talking about this one>>>
            • Warren F.
              • December 1, 1987
              • 1516
              I haven't seen one of those before. Except for the rounded corners it is the same style, dimension as the transmission tag. Interesting.
              • Peter L.
                • May 31, 1983
                • 1930
                The metal Posi tag shown looking like the one that was on my 1979 Malibu. I do not know the years other than 1979 that these tags were used. Pete
