Disassemble 2X4 Air Cleaners - NCRS Discussion Boards
  • Steven B.
    • June 30, 1982
    • 3990
    I want to remove the flame arresting material and screens from my '57 2X4 air cleaners so I can remove two small dents. Before I do, has anyone ever disassembled them, how should I proceed, and what should I look out for so as not to damage them? It seems straight forward but---
    Thanks!
    Steve
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Disassemble 2X4 Air Cleaners
    Thanks!
    Steve
    With care you can open them (about 60%) then you can remove the bottom plate , then you need to brake the screen spot welds and then re-spot weld them . Using a sharp strong blade to start and a needle nose worked good for me.
