Engine compartment spruce up - NCRS Discussion Boards
  • Joe R.
    • May 31, 2006
    • 1822
    I could use some ideas on how to spruce up the engine compartment on my 66. The engine is out right now. The front clip needs to be replaced due to front end collision damage. But I'm not going to replace it at this time. What do you all suggest?
    Joe
  • Bruce C.
    • April 1, 2006
    • 59
    Re: Engine compartment spruce up
    Joe, go here:
    I have used both PS21 and natty's and I'm very happy with the "look" of both. The only thing they lack is "slickness" I don't get that slick feel when sliding a MF across the finish like you do with UPP for instance. I was wondering if #16 is "slicker" than the previous 2 and also if it...
    Lots of photos. Good luck.
    • Joe R.
      • May 31, 2006
      • 1822
      Bruce,
      Thanks for the ideas. That's enough to get started.
      I was thinking about getting a steam cleaner at Harbor Freight. Would a steam cleaner obliterate any original markings?
      Joe
      • Don W.
        • September 30, 1997
        • 492
        Here's another one to look at....Don
        Having been part of the detailing community for more than a quarter-century, we realize a lot goes into the science and art of car care - and new products and techniques come along seemingly every day. That's why we've written numerous blogs and how-to guides for all experience levels that will teach you the ins and outs of detailing. Whether you're about to attempt your first detailing job or are
        • Bruce C.
          • April 1, 2006
          • 59
          Joe, I don't think I'd use steam.
          Read the posts on these detailing sites carefully and I think you'll discover they shy away from steam, relying more on the various products in concert with soap and water.
          Be careful with scrubbing on all hand-applied markings as they are quite delicate, in my experience.
          • Joe R.
            • May 31, 2006
            • 1822
            Bruce,
            Sounds good, I'll stay away from steam.
            Joe
            • Joe R.
              • May 31, 2006
              • 1822
              What markings should I be careful with in the engine compartment?
              Joe
              • Steven B.
                • June 30, 1982
                • 4002
                I use either warm soap and water with toothbrush and soft cloth to maintain markings but if there are no markings in the immediate area or original paint that may come off I just use my power washer, first on low pressure to see if that removes grease and soil. If not I use higher pressure, but this is usually only in the areas around zerks. On the front crossmembers of my '77 and '78 since I have FE-7 markings I just carefully wiped around them.
                If using a power washer spray in the direction from the painted surface to the area where the paint has chipped off, don't spray from chipped surface to painted or the paint will peal off very easily. I learned that on a Datsun 1600!
