'58 Question - NCRS Discussion Boards
'58 Question
  • Chuck W.
    • May 31, 2002
    • 257
    '58 Question
    Working on an early '58. Can anyone confirm or deny that the factory ever drilled holes to access the rear shocks in the fuel tank area. Please see photo.
    I just finished a slightly later '58 and there were no holes, customer believes that these holes were original. He's owned since '59.
    Thanks in advance.
  • Steven B.
    • June 30, 1982
    • 3997
    Re: '58 Question
    As I understand holes were drilled before painting the body (antenna, mirror, trim, etc.) to prevent paint chipping. If the interior areas were done the same then I would assume there may be some amount of over spray around the circumference of the holes. Alot of IF's and assumptions but worth a look.
    Were the holes covered with small round fiberous covers?
    Steve
    • Dan H.
      • July 31, 1977
      • 1369
      Re: '58 Question
      Hi, dug out my old scrap book for 58 vin #297, and have a decent shot of the bottom of the tank well, sure enough there are two holes on the top ledge of the tank area, slightly offset from the revitted-in brackets slightly below them. This car WAS drag raced, sooo, it might of been a popular mod back then? I'd look for further examples for a 'trend' etc. Regards,
      Dan
      1964 Red FI Coupe, DUNTOV '09
      • Chuck W.
        • May 31, 2002
        • 257
        Re: '58 Question
        Steve
        Customer claims there were felt-like square patches over the holes. In the photo you can see that the right one has a square bare fiberglass mark around the hole. The car went through one repaint but there was no evidence that the fuel tank/soft top well area was stripped to bare glass.
        • Chuck W.
          • May 31, 2002
          • 257
          Re: '58 Question
          Dan
          Thanks for the information Dan. Perhaps others will weigh in. My VIN 7848, a June '58 car, did NOT have these holes.
          • Rod K.
            • 443
            Re: '58 Question
            Can't speak directly re '58s, but my early '57 (and I thought all C1s) had these holes to access the top shock stud where it mounts to the shock crossmember. No other way to reach the nut to remove/install, and according to the '57 AIM, the holes were covered with Seal 3740260 (fabric?) starting in late March '57 (AIM revision date), replacing masking tape used prior. Mine shows no tape/seal outline around the holes in the primer remaining in that area, so I'd conclude the holes were sealed after paint.
            • William L.
              • December 1, 1988
              • 944
              Re: '58 Question
              Chuck; Don't know if this photo will help. This is inside the STL Plant 1958. The holes you are looking for may be there? I cant tell. Bill
              Bill Lacy
              1998 Indy Pacecar
              • Steven B.
                • June 30, 1982
                • 3997
                Re: '58 Question
                Chuck, my Dec '57 has the holes like your and they were covered with a round fiber/felt material sealed to the fiberglass with adhesive. There are no square patches like in your picture.
                • Chuck W.
                  • May 31, 2002
                  • 257
                  Re: '58 Question
                  Thanks for the information Steven
                  • Chuck W.
                    • May 31, 2002
                    • 257
                    Re: '58 Question
                    Can't see the holes but it is a great photo. Thanks Bill!
                    • Todd A.
                      • February 1, 2002
                      • 19
                      Re: '58 Question
                      My early '58 (#708) has the holes just as Dan described on his '58, however mine was also a drag racer for a good portion of its life. Through four repaints, the soft top compartment had never been stripped, but I can't remember if it had red paint within the holes or not.
                      • Ted S.
                        • January 1, 1998
                        • 747
                        Re: '58 Question
                        My late '58 (#9128) did not have the holes in the pictures for access to the tops of the shocks. Hope this helps, Ted
                        • Steven B.
                          • June 30, 2004
                          • 256
                          Re: '58 Question
                          Chuck:
                          My '58, vin #2731 has the holes you refer to--click on the photo below to see them.
                          Steve
                          • Chuck W.
                            • May 31, 2002
                            • 257
                            Re: '58 Question
                            Originally posted by Steven Berson (42243)
                            Chuck:
                            Steve
                            http://www.shrinkpictures.com/processed/phpLFnMb9PM.jpg
                            Thanks for the info Steven. The link doesn't work however.
                            • Gord H.
                              • March 10, 2008
                              • 30
                              Re: '58 Question
                              both my 58s have holes ,serial # 4300 and #6500
