Front End Align. Shims - NCRS Discussion Boards
    • 6954
    I Purcahsed Correct Style Shims But Are Plated Zinc, 4th Ed. Manuel Says Natural ,will Judges Subtract On This.
  • Sal C.
    • December 1, 1984
    • 430
    Re: Front End Align. Shims
    It depends on the judge, but I would say yes. The judge should also look for the manufacturer's logo stamped in.
      • 3416
      Hi Ed,
      I think I remember that someone recently mentioned that stripping the zinc off the shim is pretty easy. I just can't recall what they suggested using.
      I believe using a wire wheel would change the appearance of the exposed surface, so they suggested their method.
        • 6954
        Thanks For The Response Sal, originals It Will Be, I Still Have Them,I will Just Clean The olds ones up
          • 15625
          Zinc plating can be removed by soaking in lemon juice. Maybe one of our chemists will chime in with more details -- dilution, any hazards, etc.
            • 43263
            Terry-----
            Lemon juice (citric acid---a weal acid) might be strong enough to do it. If it doesn't, a tablespoon, or so, of muriatic acid (hydrochloric acid---a strong acid) in 8 oz of water ought to do it very quickly.
              • 43263
              Sal-----
              Here's a photo of a known-original 1969 shim. The area which is seen as black in the photo is the exposed area of the shim. I don't think that too much of the manufacturer's ID mark would be visible with the shims installed on the car assuming that the inner and outer shims were even installed with the ID mark side out.
                • 6954
                Re: Front End Align. Shims-JOE L.
                Joe -do You Think That Black Out Was Sparyed On The Shims From Factory The Book Does Say Natural . Thanks As Always To Everyone Who Replyed, Ed
                  • 43263
                  Edward-----
                  The black paint is some "overspray" that I am responsible for. I just pointed it out because it clearly shows the area of the shims that is exposed as it was applied with the shims installed in the car. However, it was NOT there originally and won't be there when these shims go back in the car.
