I've talked about the first and second design parts for the 55 Corvette like=
Distributors
Carb linkage
Headlights
Radiator shielding
Now water pumps, the original's has no top casting for a water outlet (left pic) that later replacement design did (right pic) but no real outlet for a fitting and they both have the same #3704911 and will fit under the original engine support.
This can be determined buy useing your finger between the engine support and pump
Dist also had the same # numbers but first design (top pic) second design (bottom pic)
