Re: basic storage question
Any nylon cord construction will tend to "take a set" when cold. This is a common problem on aircraft tires, but the "set" is rarely permanent unless conditions are extreme or the tire is underinflated or allowed to go flat, which can cause unseen internal damage.
Once warmed up nylon construction usually goes back "in round", but a nylon bias ply might take a little longer to go back in round than a radial with nylon cap belts.
After taking a car out of storage you should always warm everything up slow at low to moderate speed. Don't jump on the freeway a mile down the road. When I first start the process of taking a car out of storage I hand roll it half a tire turn to unload the flat spot area. By the time I do all the checks, get the prep done on the car going into storage, get the battery in, start the car, and go for a slow ride and hour later, there are no noticeable flat spots.
