I've got my rear spindle on a 12 ton press in an effort to change the rear bearings and trailing arm. Doesn't seem to be pushing out. Anyone know if this is normal. I was thinking of putting the torch to the inner bearing shaft race to get it cherry hot. Is this a bad idea?
Steve L
73 coupe since new
Steve L
73 coupe since new
I hold the arm at about a 45* angle, knocker tool installed and 4-7 shots the 5 lb usually get them off. Sometimes I'll use a propane to heat the race joint and then shoot some PB blaster or Kroil in there but I haven't had to use a press in a long time.
