PO2 Hubcaps - NCRS Discussion Boards
PO2 Hubcaps
  • Bryan M.
    • April 1, 1999
    • 386
    PO2 Hubcaps
    Hello,
    I have a set of what I believe to be the Corvette PO2 hubcaps. The top corner square of the checkered flag is black on three of the hubcaps and it's white on the other hubcap.
    Is it common for the checkered flag on the PO2 hubcap to change its color pattern?
    Thanks!
  • Jack C.
    • September 30, 1992
    • 1090
    Re: PO2 Hubcaps
    I believe that the checkered flag with the white square is a P02 emblem. My original P01 early 68 has the black square in the top left corner of the flag. Perhaps someone changed the emblem on the one.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Bryan M.
      • April 1, 1999
      • 386
      Re: PO2 Hubcaps
      Would this be a position held by most judges?
      The 68/69 and the 70/72 judging guide has no reference about the different flag color patterns.
      • Jack C.
        • 1090
        Re: PO2 Hubcaps
        Besides the emblem, the fins taper more to a point at the emblem area on a P02. The fins on the P01 end at the emblem as more squared off instead of a point. I too, searched both guides and came up with very little. There may be something mentioned about 6 months ago in the archieves and a photo. I don't think this is an issue for judging purposes.
        Jack Corso
        • James A.
          • July 31, 2003
          • 36
          Re: PO2 Hubcaps
          Here are a couple of photos I got from another board member. The flags appear to be the same. As previously stated the PO1 has the square fin and the PO2 the pointed fin.
          • Bryan M.
            • April 1, 1999
            • 386
            Re: PO2 Hubcaps
            Thanks guys,
            Nice pics James. You can see the difference in the two. I'll look a little closer to see if there's a fin difference between the two flag versions.
