63 Frame Restoration Questions Correct or Not - NCRS Discussion Boards
  • Ernie F.
    • March 31, 1975
    • 107
    I am restoring a rolling chassis for a customer in my shop to NCRS standards. In hopes to restore a frame correctly I began researching prior restoration pictures, documentation from other restorations, fellow forum members, and the parts as we see them when removed.
    The car is aprox s/n 5600 with 57k miles showing on the odometer. My customer requested that the frame be brought back to the original appearance and in my talks with him we considered re-tubing the drive shaft and half shafts to make them appear correct per standards. Then I remembered seeing a picture in the Noland Adams book showing a frame on the assembly line and the half shafts were not raw.
    Intrigued by this, I began researching books including the Noland Adams restoration guide. In this guide on Page 27 there is a picture of a 63 frame going down the assembly line (Pictured below). This frame clearly shows the half shafts, the strut rods, and most other parts coated black and not “raw” as suggested. I then began posting on another forum asking questions about this black substance on the suspension parts and the response there only pushed me further.
    With this in mind we started to disassemble the frame and began to notice a black substance on all the parts which included the drive shafts, the half shafts, steering gear box, and just about all other items that were deemed to be “in the raw”. Note the drive shaft pictures below which show runs of this goo on the side. Now look at the shinny areas in the picture. The shinny areas were lightly coated in this same solution and when cleaned off it was bare shinny metal underneath. The metal was so preserved it looks as if it were brand new
    In addition to these findings, we have pictures from other restorations suggesting the black out is not just a theory but indeed something that happened.
    This is the second 63 frame I’ve restored, and the forth 63-64 frame restoration. Each time in the past I have followed the guidelines set forth in the judging guide but each time I remembered finding this tar like substance on the suspension. This goo coating was always a pain in the neck to remove since it slows down sand blasting, will not dissolve in acid, and has to be cleaned off before you attempt either. Personally I would rather blast these smaller parts in our blast cabinet than to use our larger blaster which makes a mess. I never paid attention to this goo until this time around and always blamed the dealerships for undercoating the car. I wonder how may people out there have found the same stuff on their cars and had the same thought.
    My issues with doing this frame at first was do I restore the frame to the known judging standards, or do I restore it to what I believe is correct. Ultimately, this is not my decision and so I left it up to my customer.
    I’m not trying to stir up a whirl wind here, but if enough people keep finding this stuff on frames would there not be a change in order for the JG. It has been pointed out to me that the JG is just what it states “guide” and not a manual as previously issued by NCRS.
    Ernie
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 63 Frame Restoration Questions Correct or Not
    Ernie
    Thanks for the pic's Ernie. Bet this will be a very interesting discussion very soon.
    • Ernie F.
      • March 31, 1975
      • 107
      They must be watching Football!
        • 11659
        Ernie,
        See if you can go back and edit the font size up a notch.
        Not a problem for me, but I know it will be for anyone with a normal sized monitor and older eyes.
        Patrick
        • Ernie F.
          • March 31, 1975
          • 107
          Patrick,
          I tried doing this but it won't allow me or I'm not smart enough? ? ?
          Ernie
            • 11659
            Patrick,
            Ernie
            I tried to edit mine above after I posted to see if it was possible, and also can't edit the size of the font. I think it has to happen before it's posted, not at editing.
            Thanks for trying.
            Patrick
            • Michael W.
              • April 1, 1997
              • 4290
              Ernie,
              Patrick
              What? Speak up sonny!
              • Michael W.
                • April 1, 1997
                • 4290
                Ernie
                Maybe this is better?
                • Tracy C.
                  • July 31, 2003
                  • 2739
                  This is an original unrestored 63 half shaft that I have. It is still covered with a black substance similar to asphalt based paint.
                  It pretty hard to argue with production line pictures.
                  Here is another one of the front of an upturned 63 chassis. Photo credit to John Hinckley.
                  tc
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    I think the fact that there aren't many responses to your post means that almost everyone agrees, nearly everything in the rear suspension/drive for 63-64 was coated with chassis black.
                    Pretty obvious that the entire control arm, brake drum, spindle support, brake backing plate and drive flange was painted chassis black.
                    Also, the half shaft and complete differential.
                    Does anyone disagree?
                    • Kenneth S.
                      • July 31, 1981
                      • 302
                      In the both the 4th and 5th Editions of the 1963-64 Judging Manuals there is a note at the end of Section 13, Rear Suspension, that says:
                      • Paul J.
                        • September 9, 2008
                        • 2091
                        Isn't Ernie describing the "black preservative" material that was applied to the exhaust pipes at the factory with mitts? This is in Noland Adams' book, page 34. I wasn't aware that this material was put onto driveline pieces, but spillage would make sense if it was applied after the pipes were installed.
                        By the way, Ernie, thanks for the tip on trying to get it off. I'll be stripping my frame next year and it's alwys nice to know what you're up against.
                        Paul
                        • Michael H.
                          • January 29, 2008
                          • 7477
                          Thanks Ken. That certainly acknowledges the presensce of the blackout coating on these components.
                          I suppose it would be even more accurate if the wording was changed to state that these components "should be coated with black".
                          • Ernie F.
                            • March 31, 1975
                            • 107
                            Kenneth,
                            I’ve seen that but the stuff I’m seeing is not a semi gloss black, it’s more like a tar coating in most places. Under this coating on the drive shaft and the half shafts there is no black, just raw steel. On the steering gear box, we had to remove the black to get to the yellow marks. This was exactly the same on most the front suspension items that are to have the striped paint markings.
                            On the steering box, this stuff appeared harder than what is on the rear components. I don’t know if this was due to curing from the heat off the manifold or what. On the lower suspension a-arms it was more like the rear drive shafts.
                            So, if I do this frame correctly, I restore it them mark it and then cover the marks with black.
                            Paul: Just a note, if you blast this stuff it will slowly come off. But if you use good parts cleaning solution and just keep wiping on it eventually it will come off. It’s easier to use the solution unless you have a Tip 90 blaster which will blow through it (and blow sand everywhere). The standard DIY Blasting cabinets will take to long and just dirty up your sand.
                            Ernie
                            • Stuart F.
                              • August 31, 1996
                              • 4676
                              I'm more inclined to stick with "may" rather than "should". I can't recall any degree of black out on mine; exhaust system or rear suspension, from day one. It's possible we burned it off on our intial trip from Wisconsin to New Mexico in August of 1963, but I think it would have taken a lot of gravel road drives to remove it from the rear suspension - and I know we never did that.
                              Soon after our arrival in New Mexico, we had an electrical short in the starter and I recall driving the car onto an embankment so I could crawl under to check it out. I got a pretty close an intimate look at the underside, which was fasinating to view something so unique at the time (first independent rear suspension, etc.).
                              My half shafts to this day just have a nice even coat rust on them. In fact, I would be concerned if they had any kind of globbing undercoat on the half shafts or drive shaft for fear of balance effects.
                              Mine was a July 9 build. May be they learned to forgo that by that time as they sought to find ways to remove cost out.
                              Stu Fox
