Real 4346 - NCRS Discussion Boards
Real 4346
  • Edward M.
    • November 1, 1985
    • 1922
    Real 4346
    What do you think, is this a real 4346 fuel pump.
  • Henry F.
    • April 1, 1979
    • 68
    Re: Real 4346
    It looks real to me!
    Hank
    Hank Fredella
    Vice Chairman Northeast Chapter
    Charter Member (1982)
    Webmaster www.necncrs.homestead.com
    • David S.
      • December 1, 1982
      • 310
      Re: Real 4346
      Hi Ed,
      The owner states in answering a question that there is no AC on the bottom cover.An original pump would have this marking on the bottom cover.I also believe that the AC shown at the inlet port is also not correct.
      I think a judge would give a small deduct for this pump.
      Dave
      • David S.
        • December 1, 1982
        • 310
        Re: Real 4346
        Hi Ed,
        I also failed to mention that the side bolts are much to long.
        Dave
        • Barry H.
          • April 30, 1976
          • 213
          Re: Real 4346
          Ed, ALSO The tapped hole in the center section appears to be 3/8 " pipe thread. Should be 1/4 " There is also a debossed part # on the center section It is 1538354 (just to the right of the outlet hole).
          Barry Holmes #940
          • Edward M.
            • November 1, 1985
            • 1922
            Re: Real 4346
            Two other things that bother me, but I am not sure about them.
            1. I sort of expect to see a casting seam around the mounting flange (where the 4346 number is). I have seen two known originals, and both had this flange casting seam.
            2. The size of the 4346 looks bigger to me that others I have seen.
            Still not sure, but leaning towards a "restoration" 4346.
            • Bob J.
              • December 1, 1977
              • 714
              Re: Real 4346
              Ed, you're leaning in the right direction
              • Gord H.
                • March 10, 2008
                • 30
                Re: Real 4346
                The one on my 58 has flush bolts, marking on top of flange A C is smaller than shown. AC on bottom. 1538354 stamped on main body.casting # is on forward half of seam on mounting bracket.and is half the size of what is shown in pictuee.
                • David S.
                  • December 1, 1982
                  • 310
                  Re: Real 4346
                  Hi Ed,
                  Just recently the fuel pump on my 57 (bowtie car) gave up after 50 years.
                  I was able to take many pictures while I had it out.Will post a few showing the #4346 pump.
                  Dave
                  • Henry F.
                    • April 1, 1979
                    • 68
                    Re: Real 4346
                    I stand corrected, after crawling under my 57, and scraped away the grease, I found the "AC" on the bottom, sorry about that!
                    Hank Fredella
                    Hank Fredella
                    • Joseph T.
                      • April 30, 1976
                      • 2074
                      Re: Another Real 4346
                      Originally posted by David Smith (6248)
                      Hi Ed,
                      Dave
                      Here is a real 4346 on a real fuelie engine..unrestored. Casting line on flange as previously commented on etc..Also see 50 plus year old original engine paint. Ac on top small ac on bottom. Notice where the bold ends finish.
                      Joe
                        • May 31, 1974
                        • 8389
                        Re: Real 4346
                        the inlet brass fitting on your pump doesn't appear to be the hex 45 degree fitting used on all the 57's etc. perhaps the photo is deceiving me. can you post a picture of the fitting from different angles?mike
                        • David S.
                          • December 1, 1982
                          • 310
                          Re: Real 4346
                          Hi Joe,
                          When I removed my 57 fuel pump I found grade 3 bolts with TR head markings.Can you tell me what the head markings are on your fuel car.
                          Thanks Dave
                          • John D.
                            • December 1, 1979
                            • 5507
                            Re: Real 4346
                            Ed, That ebay master cylinder was discussed today by Barry Holmes at Pittsburgh chapter judging seminar (we judged a 94). Anyhow the one on ebay is a fake. Not the real deal. Pass on it. John
                            • Joseph T.
                              • April 30, 1976
                              • 2074
                              Re: Real 4346
                              Mike..I will try and get some more pictures posted from another angle...however since this engine came out of an Eb Rose / Carroll Shelby driven former 57 factory race car it is possible that the fuel line and fitting may have been changed.
                              Smokey liked to move the fuel line to the outside of the frame rail. The original 4346 is also in the Nassau car. When time permits I will photograph that one too.
                              Joe
