carpet underlayment - NCRS Discussion Boards
carpet underlayment
  • Lyndon S.
    • April 30, 1988
    • 1027
    carpet underlayment
    I am going to replace my carpet in my 71 454 4 speed coupe. Most likely with the Al Knoch set.
    I replaced the original carpet in the early eighties from some that I bought from Corvette America, if my memory serves me. When I replaced the original it was made by JP Stevens , at least that is what was under the rear carpet with a small affixed paper tag.
    When I removed the drivers and passenger side carpets there was nothing under them, like a underlayment. It was just jute and on top was the carpet. So when I went back with the replacement carpet that is all I did was to put in back down with bare fiberglass in the floor boards. Like I had found it. My question is did the factory leave out a underlayment in my car? What was the original type underlayment in the 70-72 years?
    I would like to go back with some type of underlayment to knock down the cabin heat from the big block, I am looking at using a product called Dynamat. That is also why I was looking at the carpet from Mid America with its built in foil backing to keep that exhaust heat out. I know that they make it in different thickness . Has anyone came across a early C-3 car with out the factory underlayment? And just the carpet with the jute?
  • Ken B.
    • May 31, 2006
    • 233
    Re: carpet underlayment
    When i did my carpets last year i found this stuff that is very close to dynamat but alittle less expensive.It's called B Quiet ultimate.You can find it on the web.I really liked the product.
    • Lyndon S.
      • April 30, 1988
      • 1027
      Have you seen a big improvement in the cabin with less heat?
      • Ken B.
        • May 31, 2006
        • 233
        Big difference..I think lower than when it was new
        • Mike M.
          • May 31, 1974
          • 8410
          dynamat-type floorpan insulation material makes a BIG improvement in reducing cockpit heat which was a real problem with the c-3's. i also use it in my c-1 and c-2's. mike
