82 Wheel Caps loose - NCRS Discussion Boards
82 Wheel Caps loose
  • Richard B.
    • November 1, 2001
    • 58
    82 Wheel Caps loose
    I have the Alum wheels with a plastic cap in the middle that is a tad loose. It snaps in, but seems ready to come off with a good bump. I saw some red "stuff" around the contact area. What can I use to secure the plastic cap to the wheel???
  • Dick W.
    • 10483
    Re: 82 Wheel Caps loose
    Silicone is the best thing that I have used. RTV
    Dick Whittington
    • Richard B.
      • November 1, 2001
      • 58
      Thanks, Dick,
      I'll give it a try, may have half a tube in the box. And RTV does stand for Real Tough Vaseline, right?
      Thanks for the help.
      Rich.....
      • Steven B.
        • June 30, 1982
        • 3989
        Rich, I think you have a common problem. My original '77 centers became loose and popped off alot. I tried a bit of silicone and it seemed to help so far. I am seriously considering getting new center caps and not worrying about losing the originals.
        • Oliver B.
          • February 1, 1992
          • 556
          I lost two on my '77 (15 years ago), too. Replacements showed no weak points ever since...
          • Steven B.
            • June 30, 1982
            • 3989
            I have also had teeth that grip the wheel break on my original caps. I guess over time they weaken and lose surface material and wear down allowing them to no longer fit tightly against the wheel.
            • Grant M.
              • August 31, 1995
              • 448
              When we had our 78 and it exhibited this problem I solved it with small bits of the black 'dum-dum' putty between the cap and the wheel. Never had a problem with them loosening and the caps remained easily removed for wheel cleaning etc.
              grant
              • Richard B.
                • November 1, 2001
                • 58
                Thanks to all! I Guess I've been lucky so far. I'll get some RTV and pucky it up in a few weeks. It looks like it may be in the garage for the season right now. Just changed all the fluids, battery, and a new set of tires, so I will be ready for the spring.
                Rich.....
