In the pictures the vent rubber on the outside of the door does not come all the way to meet the back rubber and close the gap. Can a few of you look at your roadsters and see if this is correct. These rubbers are from corvette rubber and they say thats the way they are made. It just does not look right.The vertical post will move a little closer once the screw and stop are put in and close the gap at the inside of the window. I sent the pictures to Corvette rubber also, they said that there correct and made to GM drawings. Anyone else have corvette rubber in there roadster vent windows and have this problem.
Thanks Mike
Thanks Mike
