Help Identifying part numbers - NCRS Discussion Boards
  • David D.
    • January 1, 2005
    • 416
    Having hard time figuring out what application the following part numbers are used in.......
    Examples Are:
    Ignition
    - 12338665
    - 12338662
    - 12338659
    Parking brake lever
    - 15594178
    - 15594177
    • 43238
    Re: Help Identifying part numbers
    Examples Are:
    Ignition
    - 12338665
    - 12338662
    - 12338659
    Parking brake lever
    - 15594178
    - 15594177
    David-----
    These are all REPLACEMENT part numbers, never originally used on any Corvette. Here are the applications:
    12338665-----condenser, most 1958-74 applications (non Uni-Set)
    12338662-----primary lead (wire), most 58-70 applications
    12338659-----point set, most 66-74 applications, standard breaker spring tension (non Uni-Set)
    15594177----parking brake lever, 1958-64, left side
    15594178----parking brake lever, 1958-64, right side
