Big ball antenna mast - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
    From what year to the last year were the big ball antenna masts used on C-3s?
    Scott Sims
    Texas Chapter
    • 15599
    Re: Big ball antenna mast
    Started in 1969. Someone else will have to supply the last, but I know it went through 1972.
      • 43221
      Terry and Scott----
      If we're talking about the MAST TIP STYLE, it was used from 1969 through 1977.
        • 15599
        Terry and Scott----
        That is what I took it Scott was asking about, and why I responded as I did.
        • Jeffrey S.
          • May 31, 1988
          • 1882
          Joe and Terry:
          If I'm not mistaken, '67 and '68 used the same size (.300") ball as '69 up. I know the mounting was a different configuration but I believe the mast and ball were the same. Please correct me if I'm wrong-this won't be the first time or the last!
          Jeff
          • Jeffrey S.
            • May 31, 1988
            • 1882
            Sorry- I just noticed the question was on C-3's. My including the '67 was in error.
            Jeff
              • 43221
              Originally posted by Jeffrey Salz (13182)
              Joe and Terry:
              Jeff
              Jeff----
              The mast ball was the same size for 67-68 as for 69-77. However, the masts were not the same.
              • D S.
                • March 1, 2005
                • 1551
                Thanks, all. Joe, when you say the masts were big ball through 1977 but the masts were not the same are you referring to the base of the mast where the mast enters the "cone" shaped part? I noticed that with respect to the big ball antenna masts some "cones" have broader edges (see attached photo).
                  Yes, that's what they're talking about...different mast PN for '67 & '68 due to the way the lower end of the mast installed, but your pictures don't contain the difference. The '67 & '68 masts were threaded on the lower end vs. the smooth cylindrical, slip-in, design both masts in your photo depict...
                  • D S.
                    • March 1, 2005
                    • 1551
                    Guess it'll remain a mystery what year the big ball antenna masts changed from the narrow ledge cone to the wider ledge on the cone. I know the 1969-1972 has the narrow ledge cone.
