Which Vacuum Advance Can to use....? - NCRS Discussion Boards
  • David D.
    • January 1, 2005
    • 416
    I have a 327 x 365hp RE type and wanted to check and make sure I still have the correct vacuum advance can installed, before I potentially replace it.
    I know there is some differences between different cans, but wanted to get replies from yous experts.....so when I check my vacuum etc this winter....I know I am at least starting off near correct.
    Thanks in Advance,
    David
    Oh yea, and where would I look to find this kind of information in the future?
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Which Vacuum Advance Can to use....?
    David -- You didn't specify whether your '64 L76 distrib. was T.I (1111060); early points type (1111062) or later points (1111069). No matter , as all three take the 1116236 vac can, per Delco Remy Test Spec supplement DR-324S-1.
    I don't have the benefit of the new '63-'64 TIM&JG, but if it's like the '65 book, this is the vac can called out for the 060 and 069 for that MY.
    • David D.
      • January 1, 2005
      • 416
      Wayne,
      It's the early points type (1111062) I think because it's a Nov '63 build 1964 car.....I'm also not near the car at this time. But it's definitely not a TI car.
      From other threads I've read, folks seem to always be referring to a 3 number can? Or the Napa replacement. Do I take your reply to mean that mine should have a 236 stamped on it, or a 324?
      Sorry for the confusing question, but still trying to make sense of it all. Where on the can do you find the number(s)?
      I'll also try to find in my JM.
      David
      • Wayne M.
        • March 1, 1980
        • 6414
        .... Where on the can do you find the number(s)? I'll also try to find in my JM. David
        Here's a shot of the can. There's also generic replacements; others may chime in with an equivalent aftermarket.
        • Dan H.
          • July 31, 1977
          • 1372
          David, be very careful of 'repro' 236 VA's, I had one, it split the diaphram after a year without warning. I believe Don Baker is making a high quality one, might give him a try for correct 236 unit.
          1964 Red FI Coupe, DUNTOV '09
          • David D.
            • January 1, 2005
            • 416
            Wayne thanks for the pic....
            Thanks for the heads up.....How does one get in touch or find Don Baker?
            • Dan H.
              • July 31, 1977
              • 1372
              Don Baker 815 498 9522, he's great on distributor rebuilding and super helpful with advice!!!
              Dan
              • Stuart F.
                • August 31, 1996
                • 4676
                Also, be careful of Corvette Parts Houses repros, specifically those sold by Volunteer Vette, Paragon and LIC. They don't meet specs for function. They are stamped 236 which may be fine for judging, but not for drive ability. You may still be able to get one from www.gmpartsdirect.com, their #88924985. Several of us have gotten them there recently and they check out with a Mityvac. They do have trouble keeping them in stock, so you may have to wait.
                Stu Fox
                • Joe C.
                  • August 31, 1999
                  • 4598
                  I believe this is the most recommended replacement for the 236:
                  http://www.napaonline.com/NOLPPSE/(S(r0oang45t00fmg451icdas55))/Results.aspx?Ntt=vc%201810&Ntk=Part%20Number&N=0&N ty=1&D=vc%201810&Dn=0&Dk=1&Dp=3
                  • David D.
                    • January 1, 2005
                    • 416
                    Joe,
                    I click on your link and it says " The catalog session has expired " can you do it again, or post in thread what part number you are referencing?
                    I tried to find 201801 based on link but that pulls some obscure lookin part up.
                    Thanks Again,
                    David
                    • Stuart F.
                      • August 31, 1996
                      • 4676
                      David;
                      You are certainly right to pursue whatever vendor you like; however, I went through a lengthy excercise trying to find a 236 (B28) about a month or two ago. NAPA I found has consolidated about three different VAC's under one generic part; their #1675 which is a B26. It will not meet the B28 specs; "begin @5"hg all in at 8"hg (16 degrees)" which meets Duke's 2" rule. This is critical for any L76, particularly 64's on up as that 30-30 cam has very low idle vacuum. I wanted to try one on my 63 w/the Duntov which is not so bad, and it helps.
                      I got a used one from our good friend John D. and another was sent to me by Donald L. The new one I was able to get was from: www.gmpartsdirect.com for $11.00. John H. was also able to pick up a few from them for his stock. Other than that, every other source I tried was a dead end or sent the wrong VAC (labeled 236, but not to spec on performance). I have found that even the new one had to have the stem straightened as it was dragging in the guide slot and binding in the advance plate hole. I did thjis using two sets of vice grips; one to hold the stem and the other to twist it. That way you avoid torquing the diaphragm.
                      Stu Fox
                      • John D.
                        • December 1, 1979
                        • 5507
                        Dan
                        Thanks for the free plug Dan. We have too styles of the 236's. One for the show car and one for the drivers. They are basically the same appearance-really the same. Difference is the first batch onlly has 236 stamped in it. The 2nd batch will have the suffix. I think it's 16 but forget.
                        They are individually tested and dead nuts.
                        Call Don Baker as he is loaded with them and this ain't ebay you know.
                        No more NAPA ones. I do know a guy that has some though.
                        • Stuart F.
                          • August 31, 1996
                          • 4676
                          John D.;
                          Sorry, I would have plugged your 236's too, but I haven't heard too much about them after Carlisle. I take it they are working out well and you have the stock/availability now. That's great. You're performing a great service so others don't have to go through the frustration that I experienced a few months back during my search.
                          Stu Fox
                          • Joe C.
                            • August 31, 1999
                            • 4598
                            Joe,
                            Thanks Again,
                            David
                            David:
                            Go to NAPA Parts Online
                            In header, under "parts", click on Online Parts Pro SE
                            Search by part number,
                            VC-1810
                            brings you to the expired page.
                            Cost is $7.49
                            • David D.
                              • January 1, 2005
                              • 416
                              Joe,
                              Got it....thanks
                              David
