And in less than three weeks:
New Left Rear trailing arm assembly and we did it in my office gravel parking lot. Less than a week to make the decision to buying whole new assemblies, one week to get the parts, and one week to to get a local experienced mechanic to make a house call. I assisted.
I had previously taken the brake caliper off to clean and paint. When I took it off, the wheel spindle and rotor fell to the ground. Here is how it looked this afternoon:
The shock mount came out fairly easy. After removing the shock and spring bolt, jacking up the leaf spring, the shock mount nut was just loosened, and we pounded on the end of the threaded shaft with a hitch pin and hammer. Once loosened it came out easy.
With the way the spindle was broken, we didn't have to struggle with the spindle flange bolts, behind the spindle housing. We just pulled the pivot bolt and shims in the front, pulled the arm outward and the spindle flange, U joint and half shaft fell to the ground. Easier to remove the spindle shaft bolts on the ground. Here's what it looked like with the trailing arm removed:
(since I ran out of photo room, this story is continued to the next post below)
