C3 front suspension paint? - NCRS Discussion Boards
  • Doug F.
    • November 10, 2006
    • 26
    My 4th addition TIMJG is somewhat vague about the paint (or not) on front suspension components. I'm clear about the A-arms and their attached hardware, but what about the finish on tie rods, relay rod, idler arm? Thanks.
    • 15634
    Re: C3 front suspension paint?
    Tie rods, relay rod and maybe idler arm (if it came as part of the steering assembly) was, according to a former Saginaw employee, coated black before shipping to St. Louis. His story was that it was a low quality paint that was applied after the parts were assembled and dimensionally gauged. Purpose was to keep the parts from rusting before assembly. The stuff I have seen looked and felt more like grease residue than paint. All that said most folks leave these items in the "as forged" and clean state.
    Maybe John H can comment. I would expect those UAW folks doing the final alignment in St. Louis would have gone through a lot of gloves if that story were true.
      Terry, I'm not sure about C3's, but the steering linkage on all midyears was painted as an assembly at Chevrolet-Buffalo with that cheap chassis-black paint that never dried (and washed off in the rain); the linkage didn't change from C2 to C3 (except for a slight diameter increase on the relay rod), and continued to be manufactured at Buffalo through 1982, but I don't know if the Buffalo chassis-black paint process continued through the C3 era or not.
      The toe-in pit guys went through LOTS of pairs of terrycloth gloves during the midyear era due to that sticky, gooey paint.
        • 15634
        John,
        I believe that the coating process was unchanged in the C3 era -- at least for early C3s. It was still on a 3800 mile 1971 that I had a chance to work on some years ago.
          • 11692
          Note that there is still some black present on mine:
          • Doug F.
            • November 10, 2006
            • 26
            Thanks for the info. My '71 still has the original front suspension components, including the front rotors, and no rust, but everything has been painted black. This winter I am going to replace and rebuild as required. Just trying to put the correct finish on before re-assembly.
              • 3418
              Hi Doug,
              Although I don't have a good picture like Patrick's, when I started cleaning up my 71's steering components I saw remnants of black very similar to his.
