69 Tripower Linkage problem - NCRS Discussion Boards
  • Richard B.
    • December 31, 1993
    • 44
    I have a 69 L68
    I am trying to determine if I have my return spring connected correctly. I downloaded some pictures on my website to show where it is connected.
    http://home.earthlink.net/~rbottis/id20.html
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 69 Tripower Linkage problem
    My 68 L68, with same but yellow spring is mounted the same. Were the clips left off the rods for troubleshooting purposes? I know the AIM gives the spec's on the front and rear rod adjustment play.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Richard B.
      • December 31, 1993
      • 44
      Thanks, It may be normal. I guess I'll have to check the next time I find someoen with a Tripower that I can compare with.
      The clips are on the adjustment rods.
