C3 68 vs 69 wiper door actuator - NCRS Discussion Boards
  • Terry S.
    • January 1, 2006
    • 45
    Are there any obvious differences between the early 68 vs. late 68-69 coffee can shaped actuators. I now the threading on the E68 is 1/4 x20 and 5/16x18 on the L68 through 69 but is there anything else? Thanks
    • 43248
    Re: C3 68 vs 69 wiper door actuator
    Terry-----
    The difference you describe is the only difference with the "coffee can" style actuators. However, very late 1969 (from ABOUT mid-October or later 1969) use the dual pie pan style actuator.
    • Terry S.
      • January 1, 2006
      • 45
      Thanks Joe!
      • Jeffrey S.
        • May 31, 1988
        • 1890
        Terry:
        There is one other difference between the '68 early '69 and later '69 and that is the dust boot was held in place with a small screw on each end. The boot itself was shorter and did not have the last "fold". If you pull back the boot from either end (assumng you have a current reproduction) you would see a small hole on the firewall bracket and on the rear flange of the actuater. Current repros can be modified to accurately reflect this difference. I have done this on my Oct. '68 car.
        Jeff
