Where to find NOS or Near NOS 77 Spark Plug Wires? - NCRS Discussion Boards
  • Harvey S.
    Infrequent User
    • May 31, 1999
    • 24
    Looking for an NOS or Original in working condition set of spark plug wires for a 77 L-48. Does anyone know who I can call?
    Thank you.
    1966 427/450 Coupe
    Duntov Award
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Where to find NOS or Near NOS 77 Spark Plug Wires?
    NOS wires would have had to been made prior to the mfg. date of your car- and dated accordingly. You'll be unlikely to find any in the first place and it will equally be unlikely that they would still be worth installing from a functional point of view after 31 years.
    The deduct for the modern repo wires is minimal or zero, not worth the effort just for Flight Judging (IMHO).
      And, if you buy a set of repro dated wires, ohm them before you install them (max. 5000 ohms per foot) and afterwards; they're VERY fragile.
        • 43221
        Thank you.
        Harvey-----
        If I was you, I'd get myself a set of GM #12043740, aka Delco #608T, and forget all about an "original" wire set. This, of course, assumes that you intend to actually DRIVE the car. If this is a show car ONLY, then MAYBE you might want to peruse the offerings at Corvette salvage yards for an original set.
        The GM #12043740 GM lists for about 75 bucks and you should be able to get them through Delco dealers for considerably less.
        • Tom R.
          • June 30, 1993
          • 4099
          Harvey-----
          Joe
          What GM # is called out for 78 + years? Guess I always thought the HEI TVR suppression wires were all the same.
          Tom Russo
          78 SA NCRS 5 Star Bowtie
          78 Pace Car L82 M21
          00 MY/TR/Conv
            • 43221
            Originally posted by Tom Russo (22903)
            Joe
            Tom-----
            1978-82 use wire set GM #12043728, aka Delco #608D. Why the difference from 75-77? The 78-82 wires are shorter than 75-77. Why are they shorter? The wire support system changed during the 1977 model year and the new designed required slightly shorter wires. Actually, early 1977 used the 75-76 style system; late 77's used the 78-82 style system. The late system did not come into use, though, until very late in the model year; most 77's use the 75-76 style system.
            Why did they change the wire support system? I don't know.
            • Tom R.
              • June 30, 1993
              • 4099
              Most interesting...thanks Joe. Your ability to retrieve obscure detail is impressive, amazing and truly appreciated.
              Tom Russo
              78 Pace Car L82 M21
              00 MY/TR/Conv
