do I have to change my cable to install a diconnect pull switch .I have the spring cables now.1965 roadster 327
battery disconnect
Re: battery disconnect
Sal;
I use a knife type battery disconnect switch with correct spring clamp cables on my 63. Works great. Probably not as pretty as the ones with the green knob, but it has worked well for over 25 years. Got mine from I believe "Lectric Limited" back in Chicago. I have heard some horror stories about the brand "X" knob switches; not making good contact, or not breaking contact well, that I'm glad i chose the knife type.
Stu Fox- Top
Here's the Wirth knife-type disconnect switch on my '67 with the correct battery cables (I don't trust restoration batteries).
Attached Files- Top
John;
Looks just like mine except I do have a restoration battery. What ever works for you, no apologies necessary.
BTW, thanks for putting me on to the "venting" consideration for my AFB percolation problem. Not solved yet, but think we're getting close.
Regards;
Stu Fox- Top
