'59 brake & clutch pedal finish - NCRS Discussion Boards
  • Bob S.
    • August 12, 2007
    • 185
    I am having my brake and clutch pedal assembly on my '59 powder coated but can't tell if it was originally gloss or semi-gloss black. I am assuming semi-gloss but wanted to be sure.
    Advice.
    Sully
  • Mike B.
    • November 1, 2004
    • 389
    Re: '59 brake & clutch pedal finish
    Bob,
    Attached is a Word document listing many components and the assumed correct finishes. I take no credit for this list and wish that I could recall and attribute the sources from whom it was compiled. Also note that it is not gospel, but probably a pretty good guess.
    Have fun!
    Mike
    • Bob S.
      • August 12, 2007
      • 185
      Thanks Mike. That is just what I was looking for.
      Sully
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Bob, I would add...
        ...these clutch/brake pedal asys were dip painted with paint coverage only about the lower (visible) portion of the two pedal arms - maybe 2-3rds of the assembly. Painting the entire asy will not duplicate factory paint. Best, Dennis
        • Joseph R.
          • 94
          The list will be very helpful but I did not see any mention of the headlight cup (the one the bulb fits into). The ones I have are undamaged but have some rust and other corrosion. What finish should they have?
          Thanks, Joseph Rock
