Help with T-Top Storage Bags - NCRS Discussion Boards
  • Don Z.
    • August 31, 1998
    • 254
    I used to own a '75 a few years ago. I was cleaning out the other day and uncovered a set of what I believe to be original T-Top storage bags. I was hoping someone can I.D the markings/date codes on the inside of the bags. The bags are black vinyl with 3 snap closure. Inside of each bag are numerious markings. One is a triangle with "FR" stamped inside the triangle. The other marking is a circle with "TEX" & 75 stamped within the circle. Around the outside of the circle are numbers 1 thru 12 the same as a clock with the numbers 1,2,3,4, & 5 circled. Any help will be appreciated.
  • Kevin G.
    • February 1, 2005
    • 1076
    Re: Help with T-Top Storage Bags
    Here's a link to a previous thread that might help you?
    https://www.forums.ncrs.org/showthre...62673&uid=1078
    Kevin
    • Reba W.
      • 938
      Is there a date such as May 2, 1975 made with a stamp that has rollers for the items? (Like old library books or paid invoices used to be stamped)
      The TEX 75 is the manufacturer and date of the material. The other date is the assembly, and it is sometimes in red ink, sometimes in black.
      I have not seen the clock like marking you describe but it may be the manufacturer's way of encoding the month or line, etc.
      • Don Z.
        • August 31, 1998
        • 254
        Thanks Kevin & Reba. Looking at the tread regarding the '68 and some photos that were posted looks nothing like mine. My logos, TEX & FR are printed on the entire inside but i see no signs of a date stamp, not even smeared.
        Maybe someone else will have some thoughts.
          • 15609
          TEX is the manufacturer of the material the bags are made from. The bags that came in my 1970 have that logo.
          • Don Z.
            • August 31, 1998
            • 254
            Thanks to everyone. Now I know a little something regarding the bags. I just don't have a date stamp. I do believe they are original. The number around the circle lookiing like a clock with 1 thru 5 circled must be some code from the manufacture.Thanks again.
