Hi there:
I am trying to get my 64 roadster back together after replacing the dash harness. I am just about done but I can't seem to figure out how the spaded courtesy conductor connects to the glovebox switch/lamp. When I took the glovebox apart the lamp was gutted (i.e., no innards and not connected to the prior harness).
I purchased a brand new glovebox socket, switch, bulb and shield assemebly from LI Corvette. The bulb clearly snaps into and twists into the back of the socket/switch assembly. I still can't figure what holds the spaded courtesy conductor into the switch (it appears that the bulb receives its ground from the glovebox frame and its connection with the birdcage). I realize this is probably a very simple connection. Does anyone have a photo of how the spade connects or good instructions.
Many thanks,
Peter Cook
A New Member
Many thanks,
Peter Cook
A New Member
