There has been a lot of discussion on frame pull dates but after reading a number of threads, I am still not sure how to write down the frame pull date on my 65. A photo in Noland Adam's book shows a frame pull date written as day/month/year but discussion in some NCRS threads says it should be written as month/day/year. Which is correct or could it have been written either way? Thanks for any clarification.
65 Frame Pull Date M/D/Y or D/M/Y?
Tags: None
- Top
Re: 65 Frame Pull Date M/D/Y or D/M/Y?
Michael,
Believe you discover the correct sequence of numbers for the pull date are:
Month/Day/Year.
Michael
28614- Top
Michael,There has been a lot of discussion on frame pull dates but after reading a number of threads, I am still not sure how to write down the frame pull date on my 65. A photo in Noland Adam's book shows a frame pull date written as day/month/year but discussion in some NCRS threads says it should be written as month/day/year. Which is correct or could it have been written either way? Thanks for any clarification.
We've seen several original examples written either way. My April 65 frame was dated 4/19/65.
However, a St Louis assembly plant photo of frames on the frame line in late 1965 (early 66 model year) were dated DD/MM/YY.
I think the difference was probably due to different workers preference.- Top
Regarding frame pull dates.......what was the average time for a frame pull from storage as it relates to build date of the car? How many days before?
Michael- Top
The same day or not more than one working day prior to the day the car came off the line.- Top
Thanks for the responses. I am going to use the MM/DD/YY sequence and use the build date as the pull date I put on the frame.
Mike- Top
