58 windiow regulator - NCRS Discussion Boards
  • Jack A.
    • March 1, 2001
    • 129
    Greetings. A friend of mine is restoring a 58 at the same time I am restoring my 61. We need to replace both Window Regulators on the 58 but so far have only found the Drivers side. Any leads on one for the Passenger side?
    Jack 35730
  • Gary C.
    Administrator
    • October 1, 1982
    • 17971
    Re: 58 windiow regulator
    Jack, you can replace the big gears on the existing regulators. If you talking about the small cup gear that the handle goes onto you will have to probably get good used ones. Check with Paragon Tech to see if they have any. You will need to know exactly which small gear unit you need. There are two different ones. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Paul M.
      • November 1, 1987
      • 142
      Have them rebuilt. Grossmuellers rebuilds them. They are in Phillipsburg, NJ and have a web site.
      Paul
      • Jack A.
        • March 1, 2001
        • 129
        Thanks guys. One way or the other I think you've given me some good leads.
        Jack
        • Gary C.
          Administrator
          • October 1, 1982
          • 17971
          Jack, attached outlines the steps I followed when I did mine. Should've taken photos, but didn't. Gary....
          NCRS Texas Chapter
          • Jack A.
            • March 1, 2001
            • 129
            Thanks Gary and Paul,
            Gary, I printed up the information you were so kind to send and I will use it. Paul I looked up that source you referred me to and you were right. They even take exchanges to help defray the costs, Great!!
            Jack
