Well I finally managed to get my second coat of lacquer on yesterday and it turned out way better than my first attempt! No tiger stripes or mottling that I can see at all but it did form a few dry spots where I sanded the previous coat almost through, and in two spots, too the primer.
The pic of the rear deck shows a dry spot in the center of the light reflection on the pass side. I think this one was from sanding the prior coat a bit too much as the primer was just starting to show through here. There is a similar spot on one of the T-Tops too.
The pic of the whole car shows a darker spot that looks like a shadow just above the gills. This was a dry spot too that I noticed after I finished the other side so I gave it a quick shot. The dry spot went away but it shows darker from some angles. Would this spot lighten up and match the rest of the fender with a light wet sand and buff or can not much be done about it. That's kind of a moot point since I still have the final coat to put on but I'm just trying to see what I can get away with and work with when it comes time to shoot the last coat.
Oh well my goal was to try and get this coat to flow out and stay wet a lot longer than the last coat and it seemed to do that okay. For now I'll let it dry over winter and assemble the interior and engine bay so it's a running, driving car again by spring. Then when it warms up again I'll mask the jambs and hood surround and spray the last coat. But since I have it sooo close to what I think it should be(except those dry spots) I was thinking that I should practice buffing because I'd hate to ruin a good final coat after all I've been through.
So what would be the proper compounds and precedure to polish silver lacquer?
I don't know much about polishing lacquer or any paints for that matter other than a first timer like myself should only use an orbital polisher and a foam pad....oh and stay away from the sharp edges.
Any advice on products would be great too. So far I was planning on using 3M Super Duty Rubbing Compound #05955 for the initial buff but I'm not sure what to use for the final buff.
I mixed my first batch at 1-1/2:1 and ONE pass covered the car but it was very dry and a lot of it got sanded off to make it smooth enough for my next coat. This next coat was mixed at about 2 1/2:1 and it went on A LOT smoother but again ONE pass covered it all and it still wasn't quite as shiny as I thought it should be. I seem to have a reasonable gloss on the lower sides and smaller areas so I know that the gun(Devilbiss plus) is capable of a glossier finish. Maybe I'm just still moving too fast on the larger horizontal surfaces??? I really don't want to "lay it on" on the horizontal surfaces because that may promote cracking if it's too think so I really don't know what I should be doing to get more gloss in these areas. I know lacquer shouldn't be glossy before it's buffed but I do think that it should be a sort of semi-gloss or am I wrong on this?
