62 FI choke wire - NCRS Discussion Boards
62 FI choke wire
  • Joe M.
    • February 1, 2005
    • 590
    62 FI choke wire
    Anyone know the approximate length of the electric choke wire that runs from the ballast resistor to the female connector/ wire attached to the choke cover on a 62 FI ?
    Joe
  • William C.
    • May 31, 1975
    • 6037
    Re: 62 FI choke wire
    14 inches from the center of the ring terminal to the end of the connector that attaches to the FI choke lead, at least per the factory print.
    Bill Clupper #618
    • John D.
      • December 1, 1979
      • 5507
      Bill & Joe, I just measured an original and it matches the print. Actually it's a tad shorter but close enough. Did you ever wonder why the factory uses such a long harness going from the choke wire to the BR. Very sloppy job. JD
      • Joe M.
        • February 1, 2005
        • 590
        Thanks guys!
        J
