Barn Find! 66 Roadster - What's it worth? - NCRS Discussion Boards
  • Michael T.
    • October 7, 2008
    • 8
    I just found a 66 Roadster. Nassau blue with white top and white leather. 350 Hp, four speed with power windows, soft top only and tele column. Hubcap car that has been sitting outside under a tarp with the windows down for at least a year. Tank is full of crappy gas. Supposed to run but has transmission problem. Nose has been repaired poorly and has a wavy 1/2" to 3/4" gap in front of the hood. Looks like Maaco paint over original. Hurst shifter. Carpet has standing water and rodents living behind the seats. Correct intake and valve covers but missing shielding. Supposed to be matching number motor but have not confirmed. I am assuming it needs brakes, radiator, transmission, clutch, u-joints and probably trailing arms and exhaust. No power steering or brakes. Problem with one of the power windows and possibly some wiring issues under dash as I could see loose taped harness hanging from cluster. Any ideas on what I should offer?
  • Donald T.
    • September 30, 2002
    • 1319
    Re: Barn Find! 66 Roadster - What's it worth?
    The million dollar question is... what is the condition of the frame and the birdcage?
    • Michael T.
      • October 7, 2008
      • 8
      What should I look for?
      • Don W.
        • September 30, 1997
        • 492
        Here's a starting point from the on line NADA guide; you need deduct for all the significant repairs costs.
        1966 Chevrolet Corvette 2 Door Convertible</SPAN>
        Base Price
        $48,700
        Options
        4 Speed Transmission
        $1,150
        Corvette Leather Interior
        $1,000
        TOTAL PRICE
        $50,850
        Low Retail Value
        This vehicle would be in mechanically functional condition, needing only minor reconditioning. The exterior paint, trim, and interior would show normal wear, needing only minor reconditioning. May also be a deteriorated restoration or a very poor amateur restoration. Most usable "as-is".
        Some of the vehicles in this publication could be considered "Daily Drivers" and are not valued as a classic vehicle. When determining a value for a daily driver, it is recommended that the subscriber use the low retail value.
        Note: This value does not represent a "parts car".
        • Tom M.
          • 716
          pictures are worth a 1000 words
          • Rick S.
            • January 1, 2003
            • 1203
            Sounds like a total body off restoration but as Don Terry suggests , was is the condition of the frame and birdcage. That is what is going to determine the value of the car.
            Rick
            • Scott S.
              • March 1, 1979
              • 747
              My advice is to sit in the car and check the frame from your wallet to the rear of the car. Following that try to have an NCRS member look at the car. Two heads are always better than one.
              Scott Sinclair #2379
