81 transmission / clutch spline ? - NCRS Discussion Boards
  • Michael M.
    • November 1, 1994
    • 2
    I need to replace the original clutch on my 81 vette BW trans but according to parts books my vette trans could have came with 2 different splines, 10.5" 10 spline or 10.5" 26 spline. Of course its a 50 % gamble and I would like to lessen the odds so I have the correct disc pre purchased. I was hoping some members had changed the clutch out and remember if the clutch was a fine or a course spline or have both splines appeared ?
    Mike , White Rock BC (25339)
    • 43281
    Re: 81 transmission / clutch spline ?
    Mike-----
    I've never been into a 1981 clutch. However, I think the parts book you're referring to is incorrect. From 1971 to 1981, all Corvette 4 speeds used a 26 spline input EXCEPT 1978 with L-48 and, possibly, some early 1979 with L-48. These exceptions were equipped with a "Muncie" 4 speed based on the old Saginaw design, including 10 spline input. However, I'm virtually certain that all 1975-81 Borg Warner T-10's used a 26 spline input shaft.
    • Michael M.
      • November 1, 1994
      • 2
      Thanks for the info - Ill get at it.
      Mike
        It should also have a 14"-diameter 168-tooth flywheel and an 11" clutch (not a 10.5"), unless it's been "messed with".
          • 43281
          John-----
          Yes, I missed responding to that part of the question. The 10-1/2" clutches with 10 splines were also used for 1978 with L-48 and, possibly, some early 1979's with L-48. They were not used thereafter or for any 1975-81 Corvettes with Borg Warner transmission. For some reason, this "78-79 with L-48" situation has crept into some parts catalogs as being applicable to other years.
