C1 fan noise - NCRS Discussion Boards
C1 fan noise
  • Matt F.
    • June 30, 2002
    • 79
    C1 fan noise
    I have enjoyed driving my '60 this past summer, with one exception -- fan noise. Even with a clutch installed, it's super-loud and distracting.
    Can anyone offer some pros and cons of using an electric fan?
    thanks
    -Matt
    Re: C1 fan noise
    Electric fans don't come CLOSE to moving as much air as the stock fan/clutch/shroud arrangement, and place a major load on the already-marginal (generator) electrical system that doesn't charge at idle at the worst possible time. Not a good trade-off.
    • Matt F.
      • June 30, 2002
      • 79
      Re: C1 fan noise
      I stand (very) corrected. I removed the fan, the clutch, and the pulley. The noise persists when the engine runs. I used my dad's old stethoscope trick with a length of PVC, and there's a good "tapping" noise (frequency increasing with RPM increase) coming from behind the timing chain cover (how far behind, I can't tell). I'm thinking this is possibly a bad rod, or bearing, or...? it's down low, I don't think it's valve-related. Something beyond my technical ability to fix, I'm sure.
      Any thoughts?
      • Jake D.
        • August 31, 1984
        • 134
        Re: C1 fan noise
        Try to listen ON the fuel pump. If the noise gets louder, remove the pump,and see if the return spring has failed. It will make a noise similar to a rod bearing going. I had this problem on an old Monte Carlo. A new fuel pump fixed it.
          Re: C1 fan noise
          The 'tapping' or 'knocking' noise could well be a WARNING... If the cam/crank gears are worn OR the timing chain has been stretched, the noise may well be loose chain randomly 'waiving' and hitting against the inside of the timing cover...
          If this IS the case, you're playing with fire! Given too much slack, the timing chain will jump over the gear teeth, you'll lose registration and valves can hit pistons, break and 'grenade' your engine! Get the situation addressed by a competent mechanic now...
          • Bert L.
            • April 30, 1977
            • 428
            Re: C1 fan noise
            Timing chain strong candidate for noise. Park it and investigate!......
            • Jake D.
              • August 31, 1984
              • 134
              Re: C1 fan noise
              Hey Matt-- What was the outcome? Did you find out what the noise was?
              Let us know what you find.
