62 windshield washer vacuum can - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2409
    Can someone post a picture of the vacuum canister mounted? Also, what hose attaches to what?
    Re: 62 windshield washer vacuum can
    You probably want to be more specific as the vac reservoir mounted differently for FI vs. non-FI cars...
    • John F.
      • March 23, 2008
      • 2409
      250hp-327 non fuelie.
      • John F.
        • March 23, 2008
        • 2409
        Can someone post a picture of the mounting position of the vacuum can for the windshield washer for a 1962 non-fuelie?
          The illustration on page 325 in Noland's book shows it mounted on the back side of the driver's side splash shield; that same sheet is in the Assembly Manual.
          • John F.
            • March 23, 2008
            • 2409
            John, I see it in the manual, but I am trying to determine if the can sits higher than the resevoir or are is the valve on top of the can about level with the top of the water resevoir?
            • William C.
              • May 31, 1975
              • 6037
              I think you are looking at the FI location, the non-FI is on the drivers side attached to the metal splash shield under the washer jar. The holes are prepunched in the pan even if used on an FI car or a non-washer equipped car.
              Bill Clupper #618
              • John F.
                • March 23, 2008
                • 2409
                I know it's on the driver side, but should the can be lower than the resevoir. I don't see any punched holes.
                • William C.
                  • May 31, 1975
                  • 6037
                  If you have the Fifth edition judging guide, there is a nice illustration on page 71, section 20 of the Chassis group. The vacuum tank is below the reservoir, on the metal splashpan. Also shown on section B, sheet 11 of the AIM. The metal splashpan is at the level of the drivers feet, well below the reservoir. The holes are present even in FI cars although they are not used in the washer system as installed in FI cars. The splashpan is a bolt-in part, is it in place?
                  Bill Clupper #618
                  • John F.
                    • March 23, 2008
                    • 2409
                    William, My eyes were deceiving me. I found the two holes. What kind of bolts should be used to attach the can? I can't find any listed at Paragon or Corvette Central.
                    • William C.
                      • May 31, 1975
                      • 6037
                      On a '62, the "bolts" are actually studs welded onto the supports of the tank. Different than '58-61 which had actual bolts. I believe a nut and star washer are used on the bottom, but check the AIM to be sure.
                      Bill Clupper #618
                      • John F.
                        • March 23, 2008
                        • 2409
                        The vac can I bought on ebay doesn't have the studs. Any thoughts on what thread size or bolt that I can have a stud tacked on to the can?
                        • David K.
                          • February 1, 1976
                          • 592
                          Gosh, going from memory, since I installed mine. But I beleive the studs are either 10-32 or 10-24. You could make studs out of a hex head bolt and turn the round and the top of it flat. The top of the stud "flange", has a circular pattern to it. Then tack weld it on the feet, with the head toward the tank and the threaded part through the mounting holes.
                          • John T.
                            NCRS Financial Officer
                            • January 1, 1983
                            • 292
                            Even easier, use a carriage bolt and there is no work needed on the head.
                            Good luck
                            John
                            • David K.
                              • February 1, 1976
                              • 592
                              John, well yes you can, but the head would still not be correct. The stud has a head on it that has a (guess here) .030-.050 squared edge. The very head of the stud is flat, with concentric circles across the head. The carriage head bolt would also have that square on it, that is just under the head and probably will not fit in the hole provided for it, in the foot of the mounting bracket.
