Bad starter... - NCRS Discussion Boards
Bad starter...
  • Michael L.
    • July 31, 2005
    • 562
    Bad starter...
    How many amps should a starter draw when spinning out of the engine? Also, is 6200 the correct RPM without load?
    Mike
    Re: Bad starter...
    The specified range is VERY large because the exact value depends on ambient temperature, Etc. But, from the 1971 Chassis Service Manual for 12 VOLT starters, the spec is:
    (1) 50-80 Amps for 5500-10500 RPM free speed starters
    and
    (2) 65-95 Amps for 7500-10500 RPM free speed starters
    If we're talking about a 6V system, all bets are off.
      • 43285
      Re: Bad starter...
      and
      Jack and Mike-----
      I expect we're talking about a 12 volt starter since I think the car involved is a 1955 and there were not too many 6 volt systems used for 1955 Corvettes. However, if it were a 6 volt system the free speed test would be 75 amps at 6900 RPM.
