C3 68 4055 Center carb questions - NCRS Discussion Boards
  • Terry S.
    • January 1, 2006
    • 45
    Hi I have a few questions about a 4055 center carb for an April dated car:
    1. Would this carb be 4055 or a revised 4055-1 for an April 68 car?
    2. Did the lock screws for the float adjustment have:
    a. A beveled top rim?
    b. What is the correct color silver or gold for the screw and nut?
    3. The inlet fitting between the fuel line and the carb bowl has a hex head for the wrench on one side and is smooth round on the other side of the fitting. I have inlet fittings with the hex head on the carb bowl side and I also have them with the hex head on the fuel line side, which is correct? One takes a 13/16 wrench and one takes a 1" wrench.
    4. What is the correct material for the carb to air cleaner gasket?
    5. Is 5062 the correct metering block?
    Thanks in advance, Terry
    • 15616
    Re: C3 68 4055 Center carb questions
    3 = 11-inch and make sure the nut is black -- NOT gold
    5 = I think the metering block numbers are in the TIM&JG. Be sure the metering blocks have only the one set of numbers. Later replacements have two sets of numbers and are inappropriate.
    • Clem Z.
      • January 1, 2006
      • 9427
      the holley parts manual says 5062 metering body
      • John C.
        • January 1, 2005
        • 616
        1. When a bought a date matching center carb (2nd week of March) for my April built car I got a 4055-1.
        3. 1"
        4. Check the Doc Rebuild catalog. He claims to have gaskets with the correct material.
        John
