Wiper motor wiring - NCRS Discussion Boards
Wiper motor wiring
  • Michael L.
    • July 31, 2005
    • 562
    Wiper motor wiring
    OK, looked at three wiring diagrams and the ST-12, can't see where the hot wire for the wiper motor comes from on my '55. I know it grounds to the engine, via a valve cover bolt, but where should I tap for the hot wire? Run it off fuse panel? If so, what amp fuse? TIA
    Mike
    Re: Wiper motor wiring
    The wiper motor doesn't show on the '56-'57 diagrams either, but its brown power wire was connected to the ignition switch side of the ballast resistor (and that circuit wasn't fused).
    • Michael L.
      • July 31, 2005
      • 562
      Thanks! Thant will be a quick fix!
