C3 Washer Resevoir - NCRS Discussion Boards
C3 Washer Resevoir
  • Tom W.
    • April 22, 2007
    • 44
    C3 Washer Resevoir
    This is my 1st post of what will surely be many questions about my 1971 350/M20 with A/C.
    The Windshield Washer Resevoir is a bag located under the left fender near the firewall. I removed the original, cleaned it and am now trying re-install from the engine compartment. The metal rings on the bag don't easily attach to the hooks under the fender.
    If someone has already done this, then should I remove the fender side louver and install from below vs from above?
    Seems like you need hands the size of "Mini-Me" to get in there.....
    I'd appreciate any advice.
    Thanks, Tom
    Re: C3 Washer Resevoir
    It can be done, mon! It simply takes a little trial & error experimentation. Try folding the eyelets over so they're pointing downward, start them onto the bag's carrier bracket one at a time, then 'unfold' the bag into place...
      • 3420
      Hi Tom,
      I just wanted to say hello!
      I have a 71, 350/270, 4-speed Coupe, hard reservoir, not the bag you have. So I can't help as Jack has.
      I look forward to seeing you on the Board.
      • Tom W.
        • April 22, 2007
        • 44
        Thanks for the responses.
        I've discovered that the easiest method is to remove the side louver from the fender. That made the job very simple and allows access to the charcoal canister as well.
