Metallic Paint Codes - 1960 - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 941
    I am hoping someone can comment on the best formula and manufacturer for Sateen Silver. Here is a chart I found:
    Sateen Silver Metallic
    Valspar MW6001
    PPG 31928
    DuPont 4023
    RM 1203
    SW 1912
    MS 3072
    WA 2659
    Here are my questions:
    1. Is urethane BC/CC the way to go for 1960 Sateen Silver ? Everything is going water based in California but I could go to Nevada to get paint if needed. Is that an issue ?
    2. Which manufacturer should I use to best replicate the original lacquer finish with a modern paint ? I need the metallic flakes to match in size and color (i.e. avoid the pearl flakes) ?
    3. Which spray gun type should be used ?
    4. What flattener mix ratio should we use for the jambs ?
    5. What is the best way to get a professional body and paint guy up to speed for an NCRS paint job ? My friend has 25 years experience doing this full-time for a high end body shops (Lexus, Mercedes, etc.) and will do this as a side job. He is studying the TDB postings, the JM and the NCRS Paint DVD. Any good books on paint and fiberglass he should read ? I was planning to have him speak with Paul Schuster and others that could help. He will start the paint job in 6 months but wants to start planning now and doing some test panels. He will also be at the Western Regionals in Lake Tahoe to study the cars. I have known him 40 years and I have a lot of trust in him which is why I want to use him.
    Mark
  • Loren L.
    • April 30, 1976
    • 4104
    Re: Metallic Paint Codes - 1960
    There is NO GOOD FORMULA FOR SATEEN SILVER. Correctly and accurately mixed, it looks like gray primer with clear lacquer mixed into the top coat. Don't waste your $$ or your painter's time.
    • Mark P.
      • May 13, 2008
      • 941
      Loren - what about Sateen Silver in lacquer ?
      Mark
      • Loren L.
        • April 30, 1976
        • 4104
        See reply above.
