Insulation tabs going every which way - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    I've been slowly tearing up my hands glassing and sanding around the insulation retaining tabs on the firewall of my 68.
    My last "nick" caused me to use explatives that sent even my nearly deaf beagle scampering for cover.
    With that said, I decided to take a long over due break at which time I notice something odd.
    Some of the firewall insulation retaining tabs were either bent outward or inward. This also held true for the tunnel insulation retaining tabs as well.
    Is there a right or wrong way?
    Structurally speaking, if they were bent outward they would better hold and support the insulation in place.
    Any thoughts on the subject?
    Chuck
    • 3422
    Re: Insulation tabs going every which way
    Hi Chuck,
    I checked the tunnel insulation on my 71. The imprints in the foil definitely show that all 4 clips had the tabs bent outwards. Sorry, no firewall insulation. The 71 AIM only shows 2 of the clips in the drawing, but with the tabs clearly shown bent outward.
    • Chuck R.
      • April 30, 1999
      • 1434
      Thanks for taking the time to check this out for me Alan.
      Chuck
